Nya Exige - läs denna artikel!
Guest
Post by Guest »
Under Exige
There's a 142kW(190hp) Celica engine in the MKII Exige - which means Lotus's racer is more intense than ever
There's a wonderful, character-defining moment in the new Lotus Exige, just as the bright, flourescent orange needle on it's white-faced Stack rev counter kisses the 6200rpm mark, when you suddenly realise you're among the living. It's here where the coupe's new Toyota engine decides it's done with decorum and a variable valve timing mechanism vaults its lightweight internals onto a higher lift camshaft.
The accompanying increase in pace is one thing, a sudden burst of power catapulting the lithe two-seater forward with one hefty shove indeed. But it's nothing compared with the raw mechanical blare and massive thump of induction noise that assaults the depths of your inner ear.
From within the Exgie's stark, aluminum-lined interior, the sensation is violent enough to have you momentarily backing off for the first time, for fear of something very expensive, very mechanical has just gone horribly wrong over your left shoulder. After that, you find yourself piling on revs furiously at every opportunity just to experience the full force of the advanced four-pot mill again.
Addictive? You bet. Just like the rest of the car, really. Not that we expected anything else. The first Exige, launched towards the back end of 2000, was a seriously extreme machine and, against all odds, managed to find 600 buyers worldwide. So why should we believe this heavily upgraded follow-up model would be any different?
Although it's not planned to go on sale until mid-2004, Lotus granted MOTOR an exclusive run in a prototype of the new car around its legendary Hethel test track. A drive in a new Exige is one thing, but a chance to drive on the circuit designed by Colin Chapman is something no self-respecting car nut would ever knock back!
The Exige certainly looks dramatic, especially in the black paint scheme of the prototype. With track duties high on the priority list for the new car, it's equipped with some fancy aerodynamic aids. They include a draveway-scraping front splitter, a prominent rear wing mounted to the engine bay cover, and a smooth undertray with rear diffuser. Further track influences include a roo-mounted air scoop that can be used to supply cooling air to the new engine, which sits under a newly designed engine cover.
The early Exige ran and old but cheap 1.8-litre four-cylinder K-series from Rover. Simple in construction but hardly special in the area of accoustics, it served up 142kW (190hp) and 164Nm (121ft/lbs)of torque. The new model, however, is propelled by a modern and better-sounding 1.8-litre engine from Toyota, the screaming VVTi-L unit from the Celica and Corolla Sportivo.
It was chosen from a variety of different powerplants, including a turbocharged 2.0-litre from Opel and a 3.2-litre V6 from Alfa Romeo, mainly because of it's ability to pass emissions tests in the US - a market Lotus intends to re-enter next year with a Toyota-engined Elise.
Power remains the same at 142kW (190hp), and it is developed at exactly the same point on the dial at 7800rpm. Torque, however, swells by 16Nm (11.8lbs/ft)to 180Nm (132lbs/ft). But whereas you could extract it at 5000rpm in the Rover engine, you need a high 6800rpm in the Toyota before it's released.
It's peaky, but Lotus denies any loss overall in driveability. "You get similar levels of torque at low revs, followed by a distinct step-up in power near the top end," says Lotus test driver Gavan Kershaw.
So what does the new engine do for the already terrifically edgy Exige? At first, the new Toyota mill doesn't sound all that special. In fact, you're hard pressed to tell it apart from the old Rover unit under a 2000rpm load. Get the crank spinning with greater gusto, though, and it begins to feel smoother and generally more refined. Running a unique management system developed by Lotus, the all-alloy engine responds much better to moderate prods of the loud pedal, pulling strongly through the mid-range and making a crisper sound to boot.
As long as you don't demand too much - rmember, it's got less torque than a Camry - it actually feels quite lively, partly because of the car's inherent low weight. However, it's not until you enter the zone that it really begins hauling with any great conviction. Once it does, though, hang on.
Reach 6200rpm and it's like you've lit an afterburner. Power and torque skyrocket and a hard-edged growl of induction permeates it's way through the aluminum chassis, making everything vibrate, including the hairs on the back of your neck. The feeling is so utterly compelling that you continuosly find yourself dropping back a gear or two simply to experience it again.
Still, the engine isn't the only new development here. Lotus also fits the upgraded Exige with a six-speed manual gearbox, again from Toyota. Slicker, lighter, and more precise across the gates than old Rover five-speeder, it perfectly compliments the engine. "We did a lot of head scratching before we came up with the right gearing," says Kershaw. "It is the shortest set of ratios Toyota offers."
It's not all good news, though. The new driveline hardware adds 35kg (77lbs) to the Exige - most of it over the rear axle. This pushes the kerb weight close to 900kg (1984lbs)- portly by Lotus standards, but still low enough for a power-to-weight ratio around 6.3kg/kW.
Performance is yet to be validated. But Kershaw reckons it will reach 100km/h (62.1mph)in less than 5 seconds. That's pretty handy, given the moderate output of the engine.
No less important, given the dual road and track role the new Lotus is set to play, is its whip-crack reactions when you point the new two-seater down a twisty section of blacktop.
First impressions? The Exige's meaty and communicative non-assisted steering continues to astound. It feels even sharper and more committed than before. Left unchanged in the move to the new model, it's in a world of its own when it comes to feel and feedback. This is potentially the best steering of any car - ever! It's as though the rack and pinion system is hotwired to your brain, such is its quickness and responsiveness to inputs.
Helping to make more of the car's low mass is tweaked double wishbone suspension that picks up a number of developments aimed at improving the car's already haughty dynamics. They include retuned Eibach springs and Bilstein dampers, along with snubbers fitted to the forward bushes of the lower wishbones. It's all claimed to increase logitudinal compliance for imporved low-speed ride and better high-speed stability.
Barrel into a second-gear corner and there's a small trace of body roll as you get on the brakes, shift down and turn in. It's nothing too abrupt, but there's still enough give in the stiffened suspension to let you know the weight is beginning to transfer towards the outer front wheel. Then it's the turn of the tyres - 195/50 up front and 225/45 at the rear - and up to 100kg of downforce provided by the rear wing to do their work.
As with it's predecessor, the new Exige is show with extra sticky Yokohama tyres, this tmie A048s instead of the older A039s. They're basically special-compound slicks with grooves cut in them to make them road legal. They generate so much adhesion that you can attack corners at speeds you simply wouldn't contemplate in most other mid-engined rear-wheel-drive cars.
Lift off oversteer, a trait for which the early Exige is renownedm is well surpressed thanks to better control of the toe out at the rear when the springs and dampers begin to compress under heavy cornering loads.
This all leads to greater confidence behind the wheel. When I got my head around the concept of a car possessing endless amounts of grip, it became almost instinctive to use the added punch of the engine to set up four-wheel drifts at the exit of some of the tighter of Hethel's corners.
It stops brilliantly, too. Pedal feel is a little wooden, but push hard on the middle pedal and the Exige can made to pull up in rediculously short distances, thanks in part, to it's low kerb weight. Significantly, the new model gets ABS for the first time, though it's been tuned to operate only when it is really required.
When you boil it all down, the thing that makes the new Exige so exciting as you edge up to its limits is its absolute immediacy - be it the throttle, steering, chassis, or brakes. Nothing dilutes the driving experience. It's just the driver, car and road - all working as one. It comes as no surprise when Kershaw tells me that the new Exige is a full two seconds faster around Hethel than the old model. While I didn't get to drive them back to back, the advances are clear enough.
Joakim
Post by Joakim »
Låter kul, men ABS???. Verkar som dom skall försöka sälja denna vagn i USA kan man ju förstå! Bahh. Samma motor som US Elisen. Den kommer nog ha krockkuddar, bältessträckare, sidokuddar, US kofångare( stora svarta klumbar för att klarar 5 mph impactkraven), tusen varningslappar, plus en massa anti anti saker. USCH säger jag bara!
Annars är den ju smutt!
:steer:
Guest
Post by Guest »
Den kommer inte att säljas i USA. ABS är ju faktiskt ganska bra. Tror att många kunder kräver det på en modern bil.
Plus2
Post by Plus2 »
Det står ju "Price $125.000 (est)", är det Australiska dollar?
I så fall enligt Forex: $125.000 = 669 512,50 SEK
Mvh,
P-O
Guest
Post by Guest »
plus2 wrote:Det står ju "Price $125.000 (est)", är det Australiska dollar?
Mvh,
P-O
Det är helt fel, givet att de inte har några speciella biltullar eller liknande i Australien. Tidigare har nämnts 30-35 tusen pund.
Users browsing this forum: No registered users and 4 guests
