Hur är det att köra en Elise med 420 hk?
Guest
Post by Guest »
Taget från exiges.com
I have just returned from Germany after spending a day crawling over and test driving the new Lotus Esthi <2.4.
As most of you will know it is the proven S2 Elise chassis with the proven Audi/Cosworth V 6 2.6l RS4 engine. The front and rear clam are made from a new mould, giving a car that is 90mm wider than standard. Apart from providing a front splitter and extra cooling vents the redesigned clams provide the phenominal downforce and the additional space required for the 225/25 18" front wheels and 265/30 19" rear wheels (shod in Dunlop SP Sport 9000's). Visually, at a glance this car is difficult to distinguish from a standard S2 Elise. The standard brakes are replaced with Esprit brakes (320mm cross-drilled), vaccuum assist and ABS. The engine develops 420 bhp, maximum torque of 520Nm at 4500rpm. It is mounted in-line (not transvers) with the engine inclined downward towards the front of the vehicle. Not only does this lower the centre of gravity of the car but it also retains the original weight distribution ratio. The leading German after-market chip supplier can provide a 600+bhp chip for this engine if anybody feels the need for extra power. The gearbox comes from a Audi A8 diesel, since the smaller A4 gearbox could not cope with the torque generated. Top speed is electronically limited to 200mph because the tyres are only certified to that speed! Colin Chapman's hand can be seen behind the design of this variant since it comes with flexible side skirts!
The entire design sequence of splitter, dam, and side skirts produces a car that gets sucked into the tarmac. The venturi effect achieved is quite incredible. Wind tunnel tests have shown that the standard S2 at 220 kmh generates about 120 Nm of lift at the front wheels, the Esthi on the other hand produces nearly 300 Nm of downforce at the same speed same location, whilst the rear wheels are pushing into the tarmac with 350 Nm of downforce.
The car when idling makes less noise than the Exige with the engine switched off. Pull away and you hear less than you would with a well behaved 118 bhp Elise. Floor the throttle and three things happen almost simultaneously. You hear a vague whistle like an arrow going past your ears (this is the two turbos starting their work), the front of the car rears up and the rear tyres sink into the tarmac.... then the horizon falls into your lap. Gone are the days of the famous Lotus grin, because the corners of your mouth are behind your ears and your teeth are tingling. 0-60 in 3.7 secs. The application of power is breath-taking. I used to think that take-off in Concorde was orgasmic, but that seems like something for old ladies now.
Braking is equally impressive and it needs to be. The roadholding has to be felt to be believed. The company's co-owner has a history in German Elise Motorsport and scooting around the Nürnburgring and he knows how to demonstrate this car's ability on German B roads. Driving back from the airport in my Exige, it felt as though it had chromed tyres.
Production of the car starts next week (the company is the only Lotus-approved tuner in the world and registered as a car manufacturer under German law which guarantees spares support for at least 10 years and the car has type approval).
Production of the Esthi <2.7 is limited to 25 units (10 orders placed so far) The Esthi <3.7 which comes with a supercharged 248bhp K series engine is not subject to such limitation. The company's website now includes a English version and if anybody is interested further information and prices can be found here www.brandes-dschuedow.de/start_imprint.html
I was sufficiently impressed by the build quality (superb) and the owner's attitude (committed) to put my money down and buy one. The salesperson (Lutz, weinschenk@brandes-Dschuedow.de ) is a former Thielert technician, who speaks good English and lives and breathes Lotus (ask him about his Fiat 500). My original fear, that a lack of traction control would make this car difficult to handle, has proved to be wrong. Even under heavy acceleration , this baby does not wheel-spin, weave or fishtail.
This is the car I have waited for all my life and I can't wait to stretch its legs.
Guest
Post by Guest »
Lite teknisk data
ESTHI < 2.4
 • Engine  V6, Bi-Turbo mid-engine
 • Valves per cylinder  5
 • Displacement  2671 ccm
 • Compression ratio  9,5 : 1
 • HP in Kw / PS  308/420
 • Max Torque in Nm  520 at 4500 RPM
 • Gearbox  6 gear, manual,
 rear wheel driven
 • Suspension  Wilbers suspension,
 adjustable in rebound valving,
  compression and ride height
 • Brakes  320 mm disk diameter,
 4-piston calipers front,
 cross-drilled and ventilated
 • ABS  optional
 • Tyres  225/25 ZR 18 front
  265/30 ZR19 rear
 mounted on OZ Superleggera III
 • Luggage compartment  50 litres
 • Fuel tank  original, 58 L optional
 • Length/Width/Height in mm  3793/1769/1143
 • Wheelbase in mm  2318
 • Track in mm F/R  1478/1524
 • Unladen Weight   998 kg
 • Max additional weight  250 kg
 • Top Speed  ca. 305 km/h
 • Acceleration 0 - 100 km/h  ca. 3,75 sec
Johnny
Post by Johnny »
Jisses....... TA HIT !!!!!
//Johnny
lo918
Post by lo918 »
hm,hm kanske dags och bygga ut garaget (igen)
Lotus
Post by Lotus »
Swiiiiiissssssh :steer:
Lotus Elise S -07
F.n ej Lotus ägare
Micke T.
Atariman
Post by Atariman »
Nu är den dessutom till salu...ngn här som slår till kanske?  :up:
http://se.mobile.de/cgi-bin/search.pl?C ... 8&x=43&y=5
:flag:
Krister
Boxster S (Lapis Blue)
