Elise S
PeterF
Elise S
Post by PeterF »
The new Lotus Elise S : Lotus re-enters the mainstream sportscar market with a vengeance!
Lotus is back with an entry level Elise that is set to propel the Hethel based sports car manufacturer further up the sales charts. The loss of the K series engine had temporarily created a hole in Lotus' portfolio and its disappearance from the range was not good news for Pure sportscar lovers right across the globe.
The challenge of 'plugging the gap' has now been spectacularly addressed with the launch of the new Lotus Elise S -a car that will cover 0-100 km/h in a very impressive 6.3 seconds, yet sell for below EUR36.000 in lower-tax countries.
Lotus has shoehorned in a high technology 1.8-litre 136 PS Variable Valve Timing Toyota engine, which perfectly complements the phenomenal handling characteristics of the Lotus Elise. This delivers a cracking new entry-level car, capable of taking you from 0 - 100 km/h in 6.3 seconds and onto a top speed of 205km/h, law permitting!
As the new entry-level car, the Elise S may not be the fastest or quickest Elise in the range, but the acceleration, performance and handling is class leading in its price bracket and belies the cost and real substance engineered into the new vehicle - what other roadster at this price can reach 100 km/h in 6.3 seconds? For the sake of comparison, a 2.0 litre MX-5 reaches the same speed in 7.9 seconds (Source Mazda Germany website June
06)
Add this to one of the lowest depreciation rates of any car in the market and the purchase of the new Elise S becomes one of the soundest retail propositions to be found.
The Lotus Elise S is built around the revolutionary and award winning extruded and bonded aluminium chassis, with a lightweight steel rear subframe. The chassis itself weighs just 68 kg and has a stiffness of 9,500 Nm per degree.
The body design remains unchanged from the classic 192 PS Lotus Elise R (with the launch of the Elise S, the Elise 111r will become known as the Elise R) - why change the award-winning aerodynamic package and an elegant Lotus design just for the sake of it?
The car's standard specification will also delight, as nothing has been removed from the car to undermine the real value for money proposition afforded by Lotus' new 'firecracker'.
The full Lotus Elise option menu is also available on Elise S, with the exception of a limited slip differential, ensuring the new car is easy to personalize to a customer's individual requirements and preferences.
The driving experience
How does just 136 PS (100 kW) deliver such phenomenal performance?
First of all, the maximum power output is achieved at near maximum revs (engine speed) of 6,200 rpm and maximum torque (a respectable 172 Nm) is reached at 4,200 rpm. This gives a good combination of mid range pull but also encourages the driver to rev the engine to the maximum permitted engine speed of 6,800 rpm. A bright red LED "change-up light" tells the driver when to change gear, the point of illumination from the "red-line" variable and dependent on the gear selected.
Driving any Elise is an experience like no other - and the Elise S is no different. Few cars can match the delicacy and accuracy of the steering, throttle and brakes. Only a Lotus has the relatively soft springs and firm damping to give superb body control and a truly exhilarating ride.
And only a Lotus can turn in such performance with such minimal environmental impact in terms of emissions and fuel consumption.
It's all down to light weight.
Weighing in at just 860 kg, the Lotus Elise S is not just one of the lightest fully homologated sportscars in the world, but also one of the lightest cars in the world, period!
Lightweight has benefits for acceleration, the environment, handling, ride comfort and braking.
Braking comes from AP Racing callipers at the front and Brembo Calipers at the rear linked to 282 mm vented and cross-drilled cast iron discs - you can never call an Elise under braked!
The advanced ABS system incorporates an anti-lock system which is very unobtrusive and most drivers will not even notice that it is there - unless it is needed of course and even then, the system keeps a subtly low profile.
The ABS system is linked to a lightweight pedal box with steel pedal arms and extruded aluminium pads. This unit also has an electronic
(drive-by-wire) throttle for quick, smooth and more linear engine response.
Mike Kimberley, CEO of Group Lotus plc explains: "The arrival of our new Elise S is good news for lovers of Pure sportscars in all intended markets. The value for money proposition offered by the car is second to none and takes the wonderful Lotus Elise range back into the heart of the mainstream sportscar market. We now have a Lotus Elise to tempt the existing or would-be MX-5 or MG driver away from these altogether more cosmetic offerings. They now have an opportunity to get back into a car that is the very essence of what, in our view, a real sportscar should be all about!"
The Lotus Elise S is priced at:
Mainland Europe: From EUR 35.400 depending on individual
market taxes (Manufacturer's Suggested Retail Price)
(Germany EUR35.400, France
EUR36.500, Italy EUR37.936, Switzerland SFr. 52.100)
Market Availability
UK: From July 2006
Mainland EU: From July 2006
Japan and APac: From September 2006
USA: There are no plans to launch the Elise S in the USA market
for homologation reasons
Ends.
peter milton
Post by peter milton »
På tiden att Lotus fick ur sig en instegsbil till ett hyfsat pris.  :up: Trodde först att det var en kompressor variant av Elisen, den heter ju "S" precis som kompressor Exigen, engelsk logik? :kopf:
Har kört en Norfolk Mustard Yellow Elise S1 -00.
DJ
Post by DJ »
Undrar hur stora likheter det finns mellan de två toyota-motorerna.
Passar samma trimprylar etc.
Lotuslös :(
Peter S
Post by Peter S »
Det är, om jag inte har fel, samma motor som sitter i senaste Toyota MR2. Där är den ingen munter upplevelse... men Lotus kanske mappar om den för att få lite sportigare karaktär?
DJ
Post by DJ »
Peter S wrote:Det är, om jag inte har fel, samma motor som sitter i senaste Toyota MR2. Där är den ingen munter upplevelse... men Lotus kanske mappar om den för att få lite sportigare karaktär?
Men i så fall finns det väl hopp i alla fall. Nya MR2 har väl samma motor som nya celica, celican fick efter ett par år en uppgraderad variant där de utnyttjade de variabla ventiltiderna fullt ut och fick 192 hk...
Som senare hamnade i Elisen.
Lotuslös :(
Skillnaden mellan motorerna är bl a att man ej har samma topp. Elise R har en topp tillverkad av Yamaha och Elise S (S står tyvärr ej för Supercharged utan för Snik-variant !?) har en topp som är tillverkad av Toyota själva.
Visst behövs en enklare och billigare Elise som instegsmodell. MEn är denna billig nog ?
Jämfört med Elise S2 111 S (med Rover K4) så väger den nästan 90 kg mer och har 23 hkr mindre.
Det saknas minst en modell i programmet; en Elise som väger under 800 kg och som har minst 220 hkr och ett fett mellanregister tack vare en kompressor. En RS-variant alltså, för att tala samma språk som i träsket.
Mikael_W
Post by Mikael_W »
den modellen lär nog inte komma förräns exige S har mer än 220hk
Mikael, Fisker Karma
Micke !
Man har väl rätt att drömma.
Fast tyvärr har du nog rätt.
Man tycker dock att drömbilen skulle vara så läät för
Lotus att ta fram. Man har ju alla komponenterna redan.
Det enda som skulle kräva lite head-scratching var frågan
hur man på bästa sätt skulle kunna få ner vikten med drygt
100 kg.
eon
Post by eon »
Banta vikten på Elisen med hundra kilo?:
* Ja ta bort föraren.. nåväl en liten jockey får man väl tillåta.
* 20 liters tank.
* Isolering och mattor bort då.
* Stereo bort - fy Lotus, inte ens standardmodellerna ska ha det.
* Tak bort.
* Framhjul på 175mm runt om :shock:
* Bromsar bort - Ettore Bugatti sa att "Bugatti är till för att köras, inte bromsas"
* Inga extra 'driving lights'.
* Luftrenarburkarna ska bort.
* Regskyltarna - vad är de till för?
* Bakruta av plast.
* Ingen inredning i bagagerummet.
* Ventilations- och värmeanläggningen bort.
Nåväl, vad är torrvikten på en 340R?
/Erik Olsson
SÅLD: Elise 111S -03
peter milton
Erik
Väldigt drastiska åtgärder det där, men nånting ditåt vore rätt.  :up:
Det är som Lasse skriver, för mkt vikt på bilarna, men tycker jag, kanske inte nödvändigtvis för lite effekt.
Gillar min S1 mer och mer, ingen radio, inga extra driving lights, inte ens skinn ( väger inte skinn mer än tyg?, tror det iaf) :-D
DJ
Post by DJ »
Lotus har väl svaret på viktsfrågan "in-house"
S1 :lol:
S2 blev "mer bil", även på vågen.
mindre plast, mindre hjuldimension, färre inredningspaneler, så är man nog snart där.
Lotuslös :(
Ja, eller så tycker man att svaret heter Circuit Car. Den påstås väga ca 650 kg med Toyo-motorn och kompressor. Fast vindrutan får man ha på huvudet i form av en integralhjälm !
